LS7 v Comp R lifters?
Old May 24, 2008 | 02:58 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Any opinions on using the redesigned LS7 roller lifter ,supposed to good to 7K
( not the Caddy racing ones @ $230 ) v Comp "R" series ones?
Old May 24, 2008 | 01:32 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Re: LS7 v Comp R lifters?
There are some pretty strong opinions against the Comp "R" lifter if you go to camaroz28.com and look in the lt1tech section..
when rebuilding my engine I found that my comp "r"s had come apart on me like they had for so many others, I wouldn't use them again.
On my new setup I am running a stock roller lifter to 6800rpm with no troubles..
Old May 28, 2008 | 02:59 PM
Mdenz3's Avatar
Car: 91 RS
Axle/Gears: 3.42 LSD
LS7's work great, but they have a shallow pushrod cup so you'll need to check your vavletrain geometry and get the correct pushrods.
Old Jun 2, 2008 | 09:27 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
80+K miles on stock lifters... 7K limiter.... Bangin off it often
no green
Jan 9, 2016 09:22 PM
meeklay812
Oct 1, 2015 03:46 PM
