Corvette LT1 Bracket
Old May 31, 2008 | 06:42 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
Does GM sell the accessory bracket for the Corvette LT1, it looks like everything will fit well...plus it just looks a lot nicer, i saw a picture somewhere on here...I have looked on ebay, and craigslist...found nothing...if GM or anyone sells them, wether its new or used please let me know...
Thanks!
Old Jun 9, 2008 | 01:24 PM
net_coma's Avatar
Re: Corvette LT1 Bracket
I found mine on corvetteforum.com. It took some watching and waiting but I did get one. I don't think the alternator, power steering pump and etc. are compatable with the Corvette bracket.
Call the local dealer and see if it is available there and I suspect it is available at a "price". I have also seen them on ebay but a net forum is my suggestion for what you want.
Old Jun 9, 2008 | 01:40 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Is this what you were looking for? I posted this a few years back.
The vette stuff.
main bracket 12550052
p/s pulley 10227069
4 bolts for A/C compressor 11514485
shield(idler) 10210440
p/s pipe 26025172
bolt(tensioner?) 10105370
bolt(idler?) 9440111
tensioner 10227507
Gates Idler pulley(Autozone) 38015
I have lost the invoice for the p/s resevoir.
In addition to this you will need a vette p/s pump,A/C compressor, balancer, move several wires and reclock the alternator. The p/s lines are different too. I think I got to reuse my p/s pump bolts. The compressor can be bought from Autozone for $300, but doesn't come with the top plate
Old Jun 13, 2008 | 07:45 AM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I have a corvette accessory bracket in my shop somewhere. If you are still interested pm me. The only accessory that cannot be made to fit is the a/c compressor. the power steering pump can work if you turn the outlet a little.
lmk.
Kory
Old Jun 13, 2008 | 08:10 AM
Car: 88 Iroc
Transmission: t 56
oops double post
L0tuS
Oct 4, 2015 08:07 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
jerflash
Sep 24, 2015 03:11 PM
sahlomonic
Sep 20, 2015 07:15 PM
L0tuS
Sep 4, 2015 11:16 PM
