What do you guys with lt1 swaps run in the quarter?
Old May 20, 2008 | 01:03 AM
whitroc's Avatar
Car: 1986 camaro Z28 iroc
Engine: lb9 topend 350short block
Axle/Gears: stock 10 bolt 3:23
I want to put a lt1 in my 86 iroc. my current engine just lost oil presure. It had lots of problems as is. I want to put a newer and more reliable moter in the car. can i use the 4l60e the lt1s came with? could I still use the 700r4? I want to know how hard the swap would be. (wiring, mounting issues,etc)Any info is helpful.
Old May 20, 2008 | 09:08 AM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
Re: What do you guys with lt1 swaps run in the quarter?
The engine drops right in and bolts up, the trans should too although I used my T-5. Wiring isnt too bad if you have a little patience, and no how.
I ran 13.2 @106 with the hot cam kit and full exhaust installed, that was with street tires and sloppy stock suspension.
Old May 20, 2008 | 04:19 PM
DrummerDad's Avatar
Car: 1991 pontiac Firebird
Engine: 305 tbi, Lo3 (for now)
Transmission: auto
Axle/Gears: stock (for now)
Im anxious to find out also. Ive got my engine, but it needs a rebuild. So itll go in as a 355, with at least forged pistons (doesnt help, I know). Im going to try and add a locker, and gear (3.73), and weld the axle tubes. But no cam, no RRs, and only a 3" exhaust.
Im hoping for 13.7s. If not, Ill have to run up the credit card for a nitrous kit.
Old May 20, 2008 | 04:21 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
You will need a controller for the 4L60E but otherwise yes.
Old May 20, 2008 | 04:57 PM
DrummerDad's Avatar
Transmission: auto
I believe the 4L60e will work with the LT1 seemlessly, as long as you use the LT1 ecm. If you keep the 700r, you need to change some things. And if you try and use the 4L60e without the ECM that runs the LT1 (or LS1), you need a controller.
Or is that what you were trying to say?
Old May 20, 2008 | 05:27 PM
Car: 1989 GTA
Engine: 369 TPI
Yes.
Old May 20, 2008 | 08:18 PM
whitroc's Avatar
Thanks guys. I like the advice so far.
Old May 21, 2008 | 08:37 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I had bad luck with my 4l60e but that was probably just Murphy working against me..it did work fine with all the computer controls until the boom occured.
with a stock internal engine and all the bolt-ons with a t56 the car went 13.4@104 with no special prep with a 3,375lb no-driver weight.
It is much faster now but I don't ever take it to the track.
Old May 26, 2008 | 11:58 AM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I went 12.74@114 with my old hotcam and Le head combo. I haven't gotten any times with the Ai topend yet.
Kory
Old Jun 10, 2008 | 02:07 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
I am doing a swap like this too...how much work do you think it will take to get a 3250 pound car(with driver) and LT1 into he mid-low 11s? That is my goal, a good handling 11 seconf car...
i will be happy with a stock LT1 i am sure, for the moment...considering mine has a tired 2.8 in it...
Old Jun 10, 2008 | 06:14 PM
Car: 88 Iroc
Transmission: t 56
If I ever get all the bugs worked out of my current head and cam set up. I should be somewhere in the mid 11s traps should be 118-120 Hopefully I will find out for sure before the end of the summer.
Kory
Old Jun 11, 2008 | 08:39 AM
Saleen85's Avatar
My buddy ran 13.15 @ 108 with his '88 IROC, on drag radials with a 170k mile LT1, longtubes, 3.5" y-pipe, 4" single exhaust, XR1 race muffler, 6spd, tubular k-member, tubular control arms, and 3.73's in a 4th gen rear.
Some of y'all are really moving with just a cam and on street tires, what's the weight of your vehicles? His tipped the scales at 3315 with him in it, and he weighs 160lbs.
Old Jun 13, 2008 | 01:16 PM
TexasLT1's Avatar
Car: '92 RS
I ran a best of 12.89 @ 109.7 with a Hotcam and LT4 heads. that was almost 4 years ago now.
new project is in the works
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
