LT1 swap throttle cable ?
Old Jun 3, 2008 | 11:45 AM
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
Re: Engine Swap Tranny piece!
I have Question Iam doing a (94 LT1 eingine swap into a 86 IROC and what throttle cable do I use I am useing the stock throttle body the 86 stock cabel is covered plastic are should a get a cabel form LOKAR I think they make 34inch cabel for the Lt1 ?? any body help are is there a GM cabel that will work thanks
Old Jun 3, 2008 | 01:59 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
You can use a cable from a '91-'92 TPI car, it will work with a little trimming of the plastic end that fastens to the throttle cable bracket.
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
