What can i do for an intake?
Old Jul 11, 2008 | 08:50 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Hey guys. I swaped a LT1 into my camaro and the 1LE elbow i planned on using runs right into my alternator. I cant turn it upside down because the IAT sensor is too short.
I could use the stock setup but its restrictive isnt it?
What about a MAF TPI firebird elbow?
Any ideas guys?
Old Jul 11, 2008 | 09:18 PM
Firebat's Avatar
Re: What can i do for an intake?
Add wires on the IAT sensor harness and extend the length of the wires.
Or maybe ask Bingo. I think his LT1 swap has the corvette accessories.
Old Jul 11, 2008 | 09:43 PM
BCdawg57's Avatar
That is what i will do then. Adding splices into wires makes me uneasy though cause its just one more connection that can fail.
I think bingo has that ram air setup for that hood.
thanks
Old Jul 12, 2008 | 08:34 AM
Firebat's Avatar
You should have no problems with your wires if you do a good job soldering the wires together and use heatshrink-tubing. Yeah its not ideal but if done right then its not that bad either.
Old Jul 12, 2008 | 09:40 AM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I say just make a pigtail to lengthen the harness. You can get all the terminals and wires off the internet and saves you from chopping in to your harness.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
