Wiring Confusion
Old Aug 4, 2008 | 05:15 PM
Gaccett32's Avatar
Car: 1992 Firebird
Transmission: 4l60
Axle/Gears: 10 Bolt 3.08 Posi
Wiring Confusion
Firts off what I got, I have a 92 firebird with TBI, swapping in a 92 LT1 corvette. I have the service manual for the corvette. I've been reading for about a week on how to do the wiring and now I'm completely confused. I have never been very adept at wiring and the only thing holding me back is the wiring. So the first question is do I only need to splice 7 wires to make the car run without the vats based on this page... http://www.camaroz28.com/forums/showthread.php?t=474185. Or are there more wires that need to be spliced to get the car to run and if so what are they? Also I would like to try and keep the vats but based on the threads I've read on this board Im confused on how to do so. Do I only need to splice one wire or several and if so do I need the vats module from the vette to make the vats work, some posters have said you don't need the modual while others have said you do. I cant get the module so if I do in fact need it I will be OK with deleting the vats out of the ECM. Also I'm using my original tranny, and I have questions on the TCC and VSS. Since the vette was a 92 will the VSS be fully compatible or will I need to 'adjust' it to work, I have a 4l60 from a 93 firebird that I can use for VSS parts. Also the vette TCC is a five pin/wire hook up and mine is only a 3 pin/wire, do I need to delete two or one wires and hook the others up to their corrisponding pins in my original conncetor, ie A to A, B to B, etc, or something else with the wires. If this post seems confusing welcome to my world.
Old Aug 10, 2008 | 07:55 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Re: Wiring Confusion
There are several wires to be spliced at the bulkhead connecter, coolant temp, oil press, ect. also your relays need to be worked into the new engine, unless you pulled that stuff off the old car. I went with an aftermarket harness and all i had to splice inside the car was the yellow VSS wire under the pass side dash. as far as your TCC You need to look at pinouts to figure out what wire does what and go from there.
RazorN8
Jan 7, 2022 11:44 AM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
