Just a quick ???
Old Sep 27, 2008 | 10:34 PM
wht96's Avatar
Just a quick ???
I have come across a great price on a 96 lt1. i know 96 is obdII but i have a 95 computer and harness (obdI) is there anything i would have to change on the motor to use my 95 harness and comp, i know they are basically the same thing 96 has a crank sencer in timing cover and an extra set of O2's but if i use the 95 harness and comp wouldn't i be able to just "skip those". any help would be awsome. thanks
Old Sep 28, 2008 | 11:26 AM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Re: Just a quick ???
Are you sure your 95 is OBD I? I thought all 95's were OBD II.
Old Sep 28, 2008 | 05:53 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
I think you can get your 96 reprogramed to be obd I. Try pcmsforless or other programers. 95 was the last year for obd I 96 the first year for obd II (f-bodys).
Old Sep 29, 2008 | 08:03 PM
wht96's Avatar
I have heard of this i think but my problem is I already have a 95 harness and a 95 computer. I pick up the 96 motor tomorrow.
Old Sep 29, 2008 | 09:55 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
since you already have a 95 harness you must adapt your 96 engine to it.. I am running a 96 engine with a converted same year harness.. so similar but the plugs on the harness will be different.
With a 95 harness and 96 engine you will need an older type coil and (i believe) module and different knock sensor to adapt the engine.. you simply leave the cps in place with no plug and don't hook up rear O2s.. You may be able to adapt the plugs on the coil but I am not sure about that since I never had to do it, but they are different.
I ran into trouble with the knock sensor tripping a trouble code (how I found out different years had different sensors).. but pcmsforless or madz28.com can help you out with the program and any questions you might have and I highly recommend contacting them as they have done this stuff a ton more than most.
Old Sep 30, 2008 | 09:11 AM
wht96's Avatar
Awsome thanks alot for the help. I figure it would be like that buti wanted to make sure. again thanks
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
