Starter Issues with a Gen 2 350
Old Oct 12, 2008 | 08:28 PM
Alphie33's Avatar
Ok...help a concerned, pregenent, wife, help her her streesed husband solve his starter issue so he work on the nursery. The problem is as follows:
My husband has a generation 2 350 in a 87 Camaro with a worn starter. He purchased a reman starter from Auto Zone. When he placed the reman starter into the car, the gear would engage but stick in the teeth of the flex plate regardless of how he shimmed the starter. It would also stick in the teeth of the flex plate with the proper gag settings. The old starter worked but was worn and slow. Therefore, one would assume it is not the engine. Any suggestions or input anyone would have would be greatly appreciated.
Thanks!
Old Oct 12, 2008 | 09:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Congrats on the upcoming new family member. Gotta get that nursery done!
Most of the time this is a shimming problem. But, sounds like that's been covered.
Is it only sticking when the engine starts? By any chance does the car have a remote starter solenoid? It would have to have been added. Sometimes permanent magnet starters act like a generator when you tie the solenoid to the motor like you do with a remote solenoid.
If none of those add up, sounds like a bad starter. Autozone will most likely exchange it.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Wesly_66
Aug 26, 2015 09:55 PM
milk
Aug 10, 2015 06:26 PM
86Base
Aug 8, 2015 01:34 PM
