Moving to the darkside, from Buick Turbo V6 to LQ4 swap!!!
Old Oct 27, 2008 | 08:52 PM
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
Transmission: 4L60E 4000 Stall
Axle/Gears: 3.23 G80 (01 TA)
Well, I havent posted on ThirdGen.org in a while so I figure this may be the best way to come back. I took my Turbo Buick V6 engine out of my 1990 Firebird to tear it down due to a mysterious noise. Found that it collapsed two lifters, flattened one cam lobe and spun at least one rod bearing. I stopped tearing it down after that.
So, I decided to use a spare 6.0L LQ4 I had lying around for my next engine for the Firebird. All the following parts came from a 2002(or 2003) GMC Yukon;
67k mile 6.0L LQ4 w/ 317 heads(Date code 7/02 but has MLS head gaskets?)
Alternator
Starter
Power Steering pump
Water pump
Engine wiring harness
PCM
Ill be upgrading intakes for sure, as well as at least a cam swap and milled heads. I know the truck oil pan wont fit but,
The questions/confirmations I'm wondering are;
1) Can I use the accessory drive system from the yukon?
2) Can I use the Wiring Harness?
3) Are the Hawks swap headers worth it? Or are there other options?
I plan to keep checking the site for advice, comments, suggestions on the swap.
Old Oct 27, 2008 | 10:41 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: Moving to the darkside, from Buick Turbo V6 to LQ4 swap!!!
Alternator
Starter
Power Steering pump
Water pump
PCM
They likely started 2003 engines early. Lucky, means you got coated piston skirts too!
Accessory drive is usable if you retain a truck intake and chop a big-old hole into your hood. If thats not appealing you need f-body or Y-body acc & a LS1 or 6 intake.
Harness is usable. I used a '03 Silverado harness in my swap.
Hawks heads are more then worth every penny. Be sure to make your own Y though!!
Old Oct 28, 2008 | 06:46 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
I think you are defeating the purpose of the lq4 with your proposed ideas. New cam and milled heads??? The lq4's strong points are iron block and low compression. Take advantage of what that block has got. Since you have already owned a f.i. vehicle it wouldn't be a tough jump to charge that lq4. Procharger or twin turbo perhaps?
Old Oct 28, 2008 | 08:54 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Welcome back good luck on the swap! Respectively 1. no 2. yes. 3. definitely yes
Old Oct 28, 2008 | 08:55 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Well, I haven't posted on ThirdGen.org in a while so I figure this may be the best way to come back. I took my Turbo Buick V6 engine out of my 1990 Firebird to tear it down due to a mysterious noise. Found that it collapsed two lifters, flattened one cam lobe and spun at least one rod bearing. I stopped tearing it down after that.
Ouch. I don't blame you there...
The harness should work fine, I'm retaining the Escalade/Yukon harness & ECM for my swap.
Old Oct 28, 2008 | 04:07 PM
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
Id love to do the FI route with it. It is more or less a long term goal though because I wont be able to get the funding to buy a FI setup, not even an STS. So, for now Im thinking Cam and Heads(possibly cam only with boltons. Any FI is going to come with forged internals!!!
Now I remember why you cant use the truck accessories lol. I dont want any holes in the hood!
Is this a hard to wire up kind of swap? Im only using the engine side of the harness aka TH400 Transmission. Do I just splice into C101 or should I send it to Speartech or Caspers or something?
ZZ3Astro
Aug 13, 2019 12:57 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
customblackbird
Oct 1, 2015 04:30 PM
86White_T/A305
Sep 21, 2015 05:28 PM
