lq4 help
Old Nov 9, 2008 | 12:54 AM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
lq4 help
ive been looking around at the local yards for a lq4.
but how can i id it as a 6.0l lq4,
Old Nov 9, 2008 | 09:26 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Re: lq4 help
anyone know how to confirm that its a 6.0
Old Nov 9, 2008 | 09:28 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: lq4 help
The block has "6.0L" cast into the front driver's side of the block near where the water pump attaches (there's also a "6.0L" cast into the back of the block, that's the one in my avatar)... Here's a pic:
I ran some yellow chalk over the casting to make it stand out more. I don't know if that part of the block will be readily viewable with the engine in the truck and the accessories attached... I can't remember if they put the displacement on the engine beauty covers... If the intake cover says "Vortec 6000" then it is a 6.0L. Also, I think the heads on a 6.0L are a different casting than those on a 5.3/4.8L, however, I am not positive. Here is a pic of the casting # on my 6.0L head passenger side, front (also located on driver's side, rear):
Hope that helps! Good luck
Old Nov 10, 2008 | 09:19 AM
89RS305TTops's Avatar
Car: 87 Camaro Z28
Engine: LB9
Transmission: 700-R4
Re: lq4 help
Also if your lucky and the truck still has the emission's sticker on the factory airbox, that will tell you all that you need to know. If not then you will have to look for casting numbers as posted above. Good luck man, im doing this swap too, can't wait to have that Gen III power!
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
86White_T/A305
Aug 17, 2015 12:16 AM
lowerthanyou00
Feb 25, 2015 11:27 PM
BlueZee28
Feb 15, 2009 12:47 AM
