FUEL VAPOR LINE QUESTION.
Old Dec 10, 2008 | 03:18 PM
UNSTUCK's Avatar
Just did a swap to an LS1. I had to remove the evap can in order to make room for the engine. It will not be smog tested so I was thinking about just leaving it out. I know it would be best to make it fit, but it's just not going to.
Anyways, I have the fuel tank vapor line just hanging now in the engine bay and need to do something with it.
If I had a vented gas cap, could I just plug the line?
Can I run the line right into the intake manifold?
Can I just put a small K&N filter on it? I just don't want the fumes in the engine bay.
Anyother ideas? Thanks for the help.
Old Dec 10, 2008 | 04:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Vented cap and plug/remove the line is one option.
Putting the vapor canister under the fender is another.
4th gen tank with the vapor system on it is another.
Old Dec 11, 2008 | 08:53 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Re: FUEL VAPOR LINE QUESTION.
All the lines, canistor, and junk on the tank disappeared from mine.
Make sure you leave a vent line on top of the tank so air can escape when you put gas in it.
Old Dec 16, 2008 | 10:13 PM
UNSTUCK's Avatar
Thanks for your help. I think I've got it figured out now.
Old Dec 10, 2009 | 05:37 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
on my evap line i just put a filter on it but while driving apparently it leaks gas out of it. What would cause it to do that and would plugging the line and putting a vented gas cap fix the problem?
Old Jan 22, 2012 | 03:57 PM
0078red1's Avatar
Car: 1990 camaro RS
Engine: 1998 ls1. 5.7L
Axle/Gears: 4th gen rear end for got the gears
hey man i got a question i kept my evap line in my ls1 swap using third gen tank and now wondering do i just connect the plurge value line to the canister or just remove the canister and hook it up to the line on the passanger side.
theshackle
Mar 5, 2017 06:37 PM
Bryan F
Aug 18, 2015 02:28 PM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
