LT1 swap coolant/overflow tanks?
Old Feb 24, 2009 | 12:07 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
What are you guys doing for coolant/overflow tanks? I was thinking of just getting some vented overflow tank from jegs or elsewhere... Any idea if there are problems with this? I was looking to get rid of the coolant tank and keep the engine bay and empty/clean as possible, should this be ok or does anyone recommend against it and why?
Old Feb 24, 2009 | 01:23 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Re: LT1 swap coolant/overflow tanks?
I used the stock ls1 bottle under the battery and the other stock ls1 wiper bottle under the front nose.
All cleaned up.
Old Feb 24, 2009 | 01:33 PM
Car: 1992 z28
Yea, I like how that looks all cleaned up. And I am not going to run the washer fluid anyways since i am removing the wipers and wiper motor as well.
I am going to assume you have no issues with the cooling system them and you just fill the system and keep an eye on the level every so often?
Old Feb 24, 2009 | 01:54 PM
Aaron91RS's Avatar
Car: RS
I still have an overflow bottle just like a stock ls1.
There is no reason to have problems.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
