Temp Sensor keeps going bad...
Old Mar 1, 2009 | 07:14 PM
FBLT4's Avatar
Car: Firebird, Audi, Camaro
Engine: 5.7TBI, 5.7LT1, 2.8V6, 2.3I5
Transmission: 700R4, T56 coming soon
I have a 1995 LT1 from a Caprice in a 3rd gen firebird. I had an issue with random stuttering from the engine awhile back and when I hooked up a laptop to watch the ODBII stream, I saw that the CTS kept dropping to -40F randomly and causing these stutters. I changed the CTS and it worked good for a couple of days, then developed the same issue. I changed it again and it lasted for a few weeks and then developed the same issue.
Has anyone heard of this happening before or do I have a unique problem? I'm considering just hooking a switch for HOT/COLD which will output the proper voltage/resistance based on the conditions... Or I guess it could be the ECU's problem of interpreting the signal.
Anyone suggest a good way to check for that? It's intermittent which makes it difficult. I suppose I could hook a voltmeter/ohm-meter in parallel with the sensor and watch that, but would the ECU's connection affect the readings?
Old Mar 1, 2009 | 08:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You probably have a poor connection somewhere.
Old Mar 2, 2009 | 12:25 PM
FBLT4's Avatar
Re: Temp Sensor keeps going bad...
I thought of that too but it worked fine for months after the initial swap... Then I ran into these problems. I guess I could run my own loom directly from the appropriate pins on the ECU to test the theory.
Just thought I would put it out there in case it's something other people have seen before. Anyone else have any thoughts?
Old Sep 19, 2009 | 10:48 PM
FBLT4's Avatar
This thread is pretty old but just wanted to update it, The car sat for a number of months and I've been getting back into it lately, and had the same problem appear. It turned out to be a bad pigtail. I snipped the CTS connector and replaced it with one from another harness and viola it seems to be working well and consistantly now.
Old Sep 22, 2009 | 10:50 AM
screeminchicken's Avatar
Thanks for the update. posting a update or final review really help for future reference
Old Sep 23, 2009 | 07:33 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
gotta love chasing down those electrical gremlins. makes everything all that more fun, but glad to see you were able to fix the problem.
Old Sep 23, 2009 | 06:18 PM
FBLT4's Avatar
Electrical gremlins are my favorite haha. The freescan utility was indispensable at helping me diagnose it... It was clear when I saw the engine temp kept dropping to -40f and then one second later jump back to 170 or wherever it was... It was a good learning experience too. Now I know firsthand what the symptoms of an erratic/bad connection to the CTS can cause and if I ever see similar symptoms again on a car, even one without an ODBII data stream that I can read, you can bet I will eye up the CTS connector and sensor!
Old Sep 23, 2009 | 06:31 PM
five7kid's Avatar
How did you reattach the new pigtail?
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
