How do i install my lt1 crank hub?
Old Mar 3, 2009 | 10:48 PM
bmfIROC-Z's Avatar
when i pulled my lt1 apart to rebuild it i didnt know that the lt1 crank hub didnt have a keyway so i didnt pay attention to the position of the balancer/crank hub on the crank,has anyone else done this? how would i reinstall correctly? does the hub/balancer need to be installed in a certain position on the crank?any help would be appreciated,thanks in advance.
Old Mar 3, 2009 | 10:53 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Re: How do i install my lt1 crank hub?
It doesn't really matter.. however my stock hub did have some scores on it that gave a good idea of how it went on. Stock LTx engines are neutral balance on the damper. My new setup does have an ATI on it now however.
Old Mar 3, 2009 | 10:55 PM
64deux's Avatar
Car: GM WHAT ELSE IS THERE
Engine: 327 bottom tpi top
Transmission: 700r
rotate the engine to tdc on compression stroke (by hand) install dampner then mark it for ref
good luck
Old Mar 3, 2009 | 11:00 PM
bmfIROC-Z's Avatar
good luck
when i put it on tdc,should i install the hub/balancer with the arrow on the balancer pointing up?
Old Mar 4, 2009 | 06:45 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
You can do it that way or just put it on, TDC matters very little to an lt1, unless for some reason you are going with a standard distributor it simply doesn't matter for timing purposes. As far as engine balance it won't matter, stock LT1 dampers are neutral. A better idea by far is to actually have the thing keyed, thunderracing also sells a keyed damper hub. That way the thing won't spin which has happened to some folks (like me).. http://www.thunderracing.com/catalog...vid=4&pcid=239
Old Mar 5, 2009 | 01:31 AM
bmfIROC-Z's Avatar
cool,thanks guys
midge54
Dec 27, 2019 04:14 PM
Caspar
Jun 19, 2016 11:19 PM
anesthes
Mar 10, 2016 10:35 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
