1984 LS1 4L60e swap
Car: 1984 Trans Am
Transmission: 4L60e
1984 LS1 4L60e swap
Hey guys, I am an '84 Trans Am and I just purchased an LS1 and a 4L60e transmission, all of the acessories, comp and harness! im excited and cant wait for it to ship, I have a load a questions, I know that ill need to order motor mounds and a Transmission crossmember, but is there anything else that is necessairy to change, i hear that the radiator needs to be changed, is there a way to make due with the original? Also, before it is shipped, he is able to change the Computer for me, so im going to take advantage of that, so i need to know what is the standard size wheel on the 84 TA and does anyone know the gear ratio, i've heard both 3.23 and 3.42, its the 5.0L TA with the auto trans... also, does anyone have any suggestions as to what else i should have him modify before he ships it?
Thanks, Jake
Thanks, Jake
Car: 1992 camaro
Axle/Gears: 3:73
Re: 1984 LS1 4L60e swap
Not sure about the ecm but this might help out some
https://www.thirdgen.org/forums/ltx-...want-swap.html
Car: 92 Camaro RS
if ur orderin the skulte tranny x-member, you might want to do so right away. i been waitin since january and mine still hasnt shipped
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Axle/Gears: 3.23 posi
depending on how much he tweaks the computer, and the rules in your area on emissions, he could depress the codes thrown for A.I.R. or egr, any sensors you wont be running (oil level), etc... not a big deal either way, but its annoying to check codes on a perfectly fine motor and have it return 17 errors (aka mine). he could also throw your VIN on the computer if they're strict about that kind of deal as well. He should also be able to have your fans activate at a lower temp.
also the radiator problem is that you need a hose end to the radiator that isnt under pressure for the steamtubes on the top of the engine.
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Originally Posted by t0astm0nkey
Hey guys, I am an '84 Trans Am...
(Sorry, I tried to stop myself, but "smart-a$$ mode" took over...
Good luck with the swap.) Thread Starter
Car: 1984 Trans Am
Transmission: 4L60e
haha... a little typo, but i would be one of the most BaddA$$ vehicles on earth if it were truethanks for everything so far, Im going to be calling him tomorrow, so far i'm for sure going to ask him to remove the rear o2 sensors, the oil level, try to add my vin
does anyone know the stock tire size? 16" im thinkin, but dont have time in the next few days to check it out
Does anyone know what the gear ratio for the rear diff is? 3.23? 3.42? its the 5.0 TA
Thanks again guys!
colton_carlson
Mar 8, 2019 12:21 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
