LS1 swap into `89 Formula, headers problem!
Old Mar 25, 2009 | 06:17 PM
Faceman's Avatar
Car: `89 Firebird Formula LS1
Engine: LS1 HA HA HA
Transmission: 4L60
Hello,
I have almost finished my LS1 / 4L60 swap into my 1989 Firebird Formula.
Now I am having custom stainless exhaust made and we hit a snag. The right header is different than the left one, it has different exhaust pipe diameter, one has 57 mm and the other 63 mm. Is it normal or have I bought some freaky engine? The engine comes from `98 Camaro.
Also the passenger side header has to small diameter for the exhaust ports in the head and we need to bore it to make it work properly!
I would be grateful for clear information on factory headers for F-car.
Next year when I have LS6 heads on I will order a custom headers, specifically for these heads, cam etc. because those factory headers make the sparkplug change nigh impossible.
Kind regards
Marcin
Old Mar 26, 2009 | 12:05 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Re: LS1 swap into `89 Formula, headers problem!
Wow- that's odd... Do you have any pictures so that we can really see what you have?
Old Mar 26, 2009 | 03:17 AM
Faceman's Avatar
Transmission: 4L60
I`ll take them when I get the car back from the mechanic. They made a sleeve in that 57 mm one in place where headers join with the pipe, the exhaust will be connecting into y pipe behind the transmission, due to SPOHN transmission mount. I will loose some groud clearence but it`s the only way to do it. I will post pictures of my exhaust when it`s done.
Cheers
Marcin
Jorlain
Aug 24, 2022 05:11 PM
1984HO
Mar 19, 2021 11:59 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
