Throttle Cable Question
Car: 1983 Trans Am Recaro
Engine: Lt1
I have an 83 Trans Am I'm putting a 94 Lt1 into. Will the 94 throttle cable work or should I get a different one.
Engine: Lt1
Re: Throttle Cable Question
I have a reverse valve body in my TH700R4 do I have to wory about the T/V cable, and what is that anyway
Transmission: 4L80E/4L80E
The '94 throttle body won't have provision for the TV cable. Only the '93 LT1 TB had that.
Are you asking what a reverse valve body is, or what a TV cable is?
A "reverse valve body" (for those who do not know) is a transmission part that converts the shift pattern from P-R-N-OD-3-2-1 to P-R-N-1-2-3-OD. Whether or not you need the TV cable depends upon whether or not the valve body is reverse manual or reverse automatic.
A "TV" cable is the "throttle valve" cable. The throttle valve in the transmission valve body varies pressure in the transmission based on throttle position. This affects the firmness and RPMs of the shifts.
Engine: Lt1
My guess would be you would not, but it would be best to verify that with the valve body manufacturer.
Engine: Lt1
Car: 1985 Camaro Z28
Transmission: 4L60e/SS3600
Axle/Gears: S60/4.30/Spool
I also used my 94 Z28 cable. I had to bend the pedal a little to get wide open throttle but it works great.
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
