lt1 swap wont start.. injector issue?
Old Apr 2, 2009 | 10:02 PM
coryishot19's Avatar
if i spray starter fluid the motor starts and runs. the fuel pump kicks on and i have fuel pressure in the rail. i borrowed my friends injector noid tester (2 prongs and a led). crank the car and get no light on any injector either side. i pull out the dvom an and i have power going to the injectors. i traced the other wire all the way back to the ecm no kinks cuts or bends. anything any one can think of that would cause my ecm not to trigger the injectors?
Old Apr 3, 2009 | 03:39 PM
Re: lt1 swap wont start.. injector issue?
ha just read that pass key shuts off the injectors not the fuel pump. so im pretty sure that is my issue. do i just wire a ignition source through a reistor to the fuel enable wire. the how to i printed said to leave this wire open. but shopkey said it needs to read a signal to enable the injectors.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
