wiring
Old Apr 3, 2009 | 11:27 AM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
wiring
i'm trying to get all the parts i need together for my swap, and i am wondering about wiring stuff up. im going from a 91 tpi 5 speed to a 03 6.0 lq4 and a t56 from an 01 camaro. have the trans and found an engine, which will have the ecm and most of its factory harness. will i need to cut up my tpi harness to get plugs to make all the connections to the 6.0 harness though? is there someplace i could find just the plug ends i need to connect everything? what all is run off the bulkhead connectors that i will need to reconnect? i hate to hack up my existing tpi harness, its in really good shape, but is that the only way i can mfake the connections from the engine to my existing gauges, ignition switch, etc? any help at all would be great. thanks guys,
nick
Old Apr 3, 2009 | 06:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The TPI harness isn't involved in the swap. The engine to chassis harness is.
Check the LS1 swap sticky. aaron's link contains links to wiring details.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
