'04 GTO LS1/4L60E into '92 Formula
Old Apr 18, 2009 | 05:45 PM
92tracker's Avatar
Car: 92 firebird formula
Engine: 2002 LS1/6 350 rwhp
Transmission: 4L60e
Axle/Gears: 342
I am looking at changing the motor out of my 1992 firebird Formula. I presently have a 5.7 TPI with 770R4 trans I have a line on a 2004 GTO LS! with 4L60E auto trans will it fit in the same as the 2001 LS1 and trans or are they different.
92Tracker
Old Apr 18, 2009 | 07:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
We ask that you post new topics in a new thread, rather than tacking it on to another thread on a different topic. I've moved your post into its own thread for that reason.
There is an LS1 swap sticky in the top section of this forum. Take a look through that first. I believe most of your questions will be answered.
Old Apr 18, 2009 | 07:17 PM
Pocket's Avatar
Car: 91 Trans Am
Re: --- LS1 SWAP Question and Answer ---
My car was originally TBI can I use those fuel lines to run to the regulator and all that or do I need TPI lines. Seems that everyone that has done the swap was either a tpi car or a mpfi v6. What's the difference in tpi and tbi fuel lines?
Fuel lines are the same through all years/engine combos
The differences came in location (carb pass side, efi drivers) and number (evap presence or missing)
Factory hardlines will hold the high pressure required from the LSx fuel system. Up to you to decide on Vette filter/regulator combo or a return style AFPR mounted in the engine bay
12 circuit fuse box for the lsx stuff so i dont have to run **** through the firewall.
The IGN switch and gauges still need to run inside the cabin. Adding a fuse box wont change their duties
GTO oil pan will not fit, you need to swap Fbody, or other low profile pan
GTO trans will not have torque arm mounts cast into the tailshaft, either swap the 700R4 tailshaft over or use a crossmember affixed TA mount
Old Apr 20, 2009 | 08:00 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: '04 GTO LS1/4L60E into '92 Formula
92Tracker
Nice setup. There is a ton of info. on swapping in a LS1. You will probably spend hours reading through all the threads.
Old Apr 20, 2009 | 10:11 PM
92tracker's Avatar
Transmission: 4L60e
Axle/Gears: 342
I have been reading through all the info the more I read I find this will be not to bad a swap. I since have moved away from the 04 and now am looking for a 02 from a F-body as this would be some what easyer to change out.
Has anyone tried to mold the heater box to accomidate the stock coils?
Old May 15, 2009 | 08:28 AM
92tracker's Avatar
Transmission: 4L60e
Axle/Gears: 342
So far I have installed the LS1 into the 92, the frame has been notched and the A/C comp in place, the issue I have now is the steering arm will hit the A/C when I turn the steering to the right, has anyone come accross this and what was the solution.
Old May 15, 2009 | 08:50 AM
andrew69_04's Avatar
Car: 92 Camaro RS
I've not heard of this problem with any other swaps. better check mine i guess.
Old May 15, 2009 | 05:56 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Pictures? I have read many threads for when my time comes to do the swap and I have never heard of this problem.
Old May 15, 2009 | 10:04 PM
92tracker's Avatar
Transmission: 4L60e
Axle/Gears: 342
I am not sure how to put a pictuce on to the site but will try tommorrow
Old May 16, 2009 | 05:47 PM
92tracker's Avatar
Transmission: 4L60e
Axle/Gears: 342
Here's the picture of the steering arm as requested.
Attached Thumbnails '04 GTO LS1/4L60E into '92 Formula-flam-pics-031.jpg
Old May 16, 2009 | 06:01 PM
NomadTA's Avatar
Car: 11 F350 CC DRW Dsl
Haven't heard this before either. Is this an LS1 accessory setup on the car? All components in stock LS1 locations?
You could just run NASCAR tracks if that's easier. Go fast, turn left. Sorry, I'm sure that's not what you wanted to hear but I couldn't help myself.
Old May 16, 2009 | 06:51 PM
92tracker's Avatar
Transmission: 4L60e
Axle/Gears: 342
lol good answer had to laugh. All stock location LS1 out of a 02 Trans Am
Old May 19, 2009 | 04:15 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
in that picture thats the idler arm right? If it is it has a few inches you can move it up and down. losen the two bolts that hold it to the car and it will slide down some. It should give you clearence you need. Now in a perfect world with the steering centered the center link should be level so don't go lower than you need to to clear the engine. Of course this means an alignment also.
You could mount the engine up a little in the cradle also.
Old May 19, 2009 | 10:00 PM
92tracker's Avatar
Transmission: 4L60e
Axle/Gears: 342
I have removed the A/C for the moment. The ibler arm is correct the two bolts have been loosened and put to the bottom I plan on grinding off the threads above the nut and shave a little off the A/C bolt sleeve I beleive this will get me the required clearance by a 1/8 inch at the most.
Linson
Oct 24, 2025 02:00 PM
bjpotter
Oct 4, 2015 07:48 PM
