4th gen 3.4 V6 to LS1 swap HELP PLEASE
Old Jun 15, 2009 | 02:45 PM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
OK guys, here is the deal.
I bought two cars, a 88´camaro with a broken 2,8L in it and a 95´firebird with a 3.4.
I bought them to mix the old with the young style... Take the 4th gen interior with all cables/harness, dash, door panels to put it in the 3rd gen camaro.
BUT I don´t want to use the V6, so I bought a 2004 LS1 out of a Vette and mounted all the F-Body accessories on it to fit in the camaro.
My problem now is, what of the 4th gen V6 harness needs to be changed to run the ls1???
All infos and help is highly appreciated!!!
Thanks Rob
Old Jun 15, 2009 | 04:35 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: 4th gen 3.4 V6 to LS1 swap HELP PLEASE
You won't, the harness are completely different between the V6 and V8 4th gens.
I was going to do a LS1 swap in a 4th gen V6 car and I was going to have to get dash harness, cluster, BCM harness and then the harness for the engine itself as well, plus swapping out the fuel tank.
Old Jun 16, 2009 | 01:30 AM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
I already know that I have to use a 97´LT1 cluster.
BUT why do I have to change the whole interior/dash harness? These cables are for using whipers, head/iterior lights, ac, heater, turn lights and so on, aren´t they??? So why do I have to change it?
Please explain.
Now the engine´s harness. Yes, I know it needs to be changed, the best way is a LS1 one. What do you think about using a "stand-alone" Hot Rod harness?
Thanks Rob
Old Jun 16, 2009 | 06:18 AM
Klortho's Avatar
Car: 1987 GTA
The dash harness is different between the V6 cars and the V8 cars, and you won't be able to use an LT1 cluster with an LS1, they're different also.
The dash harness also has the wiring to the fuse box, the gauge cluster and everything else you mentioned as well, if you're going to use the dash, might as well use everything.
Old Jun 16, 2009 | 07:43 AM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
[quote=Klortho;4191511]The dash harness is different between the V6 cars and the V8 cars, and you won't be able to use an LT1 cluster with an LS1[quote]
Why, whats the difference?
Old Jun 16, 2009 | 12:25 PM
Klortho's Avatar
Car: 1987 GTA
One is for an LS1, one is for an LT1. The tach output is different between the two, the temp gauge on a 99+ LS1 doesn't give you the actual temp of the car, just lets you know if it's hot or not, the gas gauge is a different ohm range and the pinouts on where the engine harness plugs into the V8 dash harness is different than the V6 harness.
Old Jun 16, 2009 | 01:01 PM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
ok, that sucks... a gu on ls1tech told me that is possible.
Does a 99+ cluster fit in the 95 dash
Old Jun 16, 2009 | 02:15 PM
Klortho's Avatar
Car: 1987 GTA
The dashpads are the exact same on the Firebirds from '93+ so it will fit.
gmoutdoorsman
Oct 3, 2015 11:42 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
