wiring questions... experts needed
Old Jun 28, 2009 | 08:27 PM
brianfromhawaii's Avatar
where is stock computer located?
i wanna remove it!
what is all that wire that goes through the firewall on the passenger side? can i just snip it all?
Old Jun 28, 2009 | 08:46 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Re: wiring questions... experts needed
the factory computer is under the dash on the passengers side..as far as the wiring goes...pull off the kick panel on the passengers side and theres a clip that holds it in..remove it and your inner fender and just pull the wiring through....i wouldnt just snip anything unless you know for sure what it goes to and that you wont be needing it...
Old Jun 29, 2009 | 06:26 AM
anyone else?
Old Jun 29, 2009 | 08:11 AM
Firebat's Avatar
Yep, everything that goes through the passenger side fender is for the old computer. I plan on re-using part of that harness though, going to run my a/c controls though that harness to make the engine bay look as clean as possible.
Old Jun 29, 2009 | 09:29 PM
Pocket's Avatar
Car: 91 Trans Am
Some of the gauges and multiple fuses are ran by wiring from the C207 which connects near the PCM
If you start blindly snipping bundles of wires you will end up buying new harnesses to redo what you didnt bother to do right
Old Jun 30, 2009 | 12:11 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by brianfromhawaii
anyone else?
I'm confused. scamaro355 completely answered your questions, why do you want someone else to tell you the same things?
Old Jun 30, 2009 | 01:33 AM
simple answer - its a forum, just because i say the sky is red, are you gonna beleive me? best to have multiple opinions.
Old Jun 30, 2009 | 06:55 PM
five7kid's Avatar
The right answer is much better than several opinions.
Those who have been around awhile know this question has been answered many, many times, and always in the same way. So, a would produce the same answer scamaro355 provided, and many times over.
Another way to look at it is if scamaro355 had provided erroneous information, someone would have chimed in.
Not trying to bust you or discourage you from posting/asking questions, just trying to explain how things tend to work here.
(To contradict myself slightly, the only thing scamaro355 could have added is you need to disconnect the harness from the ECM before you can pull the harness out through the fenderwell. But, if you couldn't figure that out when you got to that point, you're way over your head on this project, anyway.)
Old Jun 30, 2009 | 07:53 PM
haha well i am used to ls1 tech where people think aluminum engines make more power than cast iron and everyones cars run 10s haha.. i like to get a few opinions... firebat gave me the exact answer i was lookin for acually
Old Jul 3, 2009 | 09:13 AM
kevinc's Avatar
Car: 1982 Z28
You might also get multiple opinions on gravity, doesn't mean gravity has more than one constant.
Old Jul 3, 2009 | 08:08 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
lol....thanks guys
IROCZ1989
Jan 24, 2016 03:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
apie2546
Aug 8, 2015 07:12 AM
