2 questions... VCM location and CAI
Where do you guys mount your ecus in the ls1 swap? and what cold air intake do you use? i am sure there is something that just so happens to fit.... or is there?
Car: 91 Firebird
Engine: 6.0
Re: 2 questions... VCM location and CAI
CAI from an '04 GTO fits ok.... not perfect, but ok
I mounted my PCM under the dash
-jason
-jason
Car: 92 Camaro RS
Same here. im running an aftermarket intake off an 04 gto. My ECM is under the dash in the stock location. it goes through the firewall underneath the ac/heater box.
Transmission: 4L80E/4L80E
Not trying to be rude, but have you even read the LS1 swap sticky? The 2nd post contains this paragraph:
"See this link for pics of where to drill the hole and how to mount PCM under dash just keep in mind to make sure you USE A RUBBER GROMMET in the firewall unlike some of the pics posted in this link as that is very risky not to.
https://www.thirdgen.org/forums/ltx-...ing-under.html"
FWIW, for LT1's and LS1's, it's called a "PCM", "powertrain control module", because it controls the engine and transmission rather than just the engine.
Here's my own thread on the topic from about 6 weeks ago.
https://www.thirdgen.org/forums/ltx-...mpartment.html
I was pretty tired when I wrote this, and no i didnt read the sticky....and i know its not called ECU... FWIW, its called a VCM not PCM
I wrote vcm in the title and ecu in the thread, dunno why. just tired I guess.
If nothing else, here you'll hear it called "PCM".
Searching on "VCM" won't get you much.
bigjay89gta
Oct 15, 2015 08:04 AM
