Double Checking Work...
Old Jul 13, 2009 | 05:23 PM
nU guy's Avatar
Car: '88 Camaro
Engine: 5.7L LT1 1995
Transmission: 4L60E (Temporary; Future: T56)
Axle/Gears: Stock Rear -3.23 from 1995 Z28
Hello everyone... I'm working on the wiring part of my swap... almost complete. I need a little help from the board.
I posted pics so you all can get an idea of where I'm at. I'm stumped on a few things:
1. Should I have another wire soldered in to the white tachometer wires to run to the tach in side the car? Or is the signal required distributed throughout the fuse block somewhere?
2. For the cranking 12 volt wire, where should I connect this?
3. I am missing 2 wires for the ALDL port: the tan wire on the C220 and the white/black on the C230. I am also missing the orange wire on the C210. What is up with this?
Help...please...
Attached Thumbnails Double Checking Work...-lt1-swap-harness-001.jpg   Double Checking Work...-lt1-swap-harness-002.jpg   Double Checking Work...-lt1-swap-harness-003.jpg
Old Jul 13, 2009 | 05:24 PM
nU guy's Avatar
Car: '88 Camaro
Re: Double Checking Work...
Last pic...
Old Jul 13, 2009 | 05:31 PM
nU guy's Avatar
Car: '88 Camaro
I forgot to mention that the harness is from an auto 1995 Z28 Camaro
Old Jul 15, 2009 | 06:37 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Im not totally familiar with that harness... But the 12v when cranking is for the circuits that need power while cranking. Know how when you crank your lights and radio will go off so more power is available from the battery? Well that wire will provide 12v with the key on, and keep 12v while cranking. So your injectors and ignition system has power to get the car fired up.
Old Jul 15, 2009 | 08:29 PM
nU guy's Avatar
Car: '88 Camaro
Thanks! Well, I found out why I'm missing the orange wire: here's why. I guess I should have done more research. As for the white wire,
I guess the 1995 or 1993 did not have the orange wire in the C210. Kind of weird, but that's how it goes sometimes with auto manufacturers.
Old Aug 7, 2009 | 10:31 AM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Did you figure everything out?
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
383cam
Sep 9, 2015 06:01 AM
tgp1990
Sep 4, 2015 06:24 AM
