lq4 bottom end
Old Jul 24, 2009 | 07:21 PM
89lt1's Avatar
Car: 1989 firebird formula, 1991 z/28
Engine: none LSX! one day, 350tpi
Transmission: none t56 one day, t5
Axle/Gears: 9-bolt 3.45, 10 bolt 3.73
lq4 bottom end
how strong is an lq4 bottom end
Old Jul 24, 2009 | 07:24 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: lq4 bottom end
crank is probably one of the strongest cast crankshafts known to man lol... rods are pretty ok, pistons are ok...good for 450-550hp with good rod bolts NA....id say maybe lil more maybe lil less....
Old Jul 24, 2009 | 07:33 PM
89lt1's Avatar
Re: lq4 bottom end
ok just wondering i did some research and everything i found said it was cast
Old Jul 24, 2009 | 07:37 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
Re: lq4 bottom end
yes but cast doesnt mean weak...whatever u do make no assumptions about GEN III motors based on traditional sbc motors... they are just soo much better in every way, not to take away from the SBC in any way...
Old Jul 24, 2009 | 07:39 PM
89lt1's Avatar
Re: lq4 bottom end
ok thanks i just want to build one and dont want to spend a ridiculous amount on a bottom
Old Jul 24, 2009 | 07:41 PM
89lt1's Avatar
Re: lq4 bottom end
and balancing would prolly help too
Old Jul 24, 2009 | 07:47 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: lq4 bottom end
If you're buying it as a longblock, take it apart and make sure the rods and pistons are still good. I bought mine assuming I could just put it in the car and go, well when I took it apart I saw that the pistons and rods were SHOT, not because of normal wear, but because someone didn't change the oil for like 10,xxx miles and it had a ton of ring blow-by. Check it check it check it!
Car: 1991 Z28 1LE
Transmission: 4l60e
Re: lq4 bottom end
its got a pretty good balance from factory, if u are going to actually build one id say have the crank prepped and order some forged rods and pistons with a good ring pack and it will handle everything u want to throw at it, a buddy of mine has a .030 over LQ4 stock crank, forged rods and pistons makeing over 500hp to the ground on motor and spraying a 200shot on it. was a daily driver till about a month ago too, good for 10s. in a 3800lb TA... and another putting 683hp to the ground with a similar setup (lower compression though) and D1SC supercharger no N2O....
check out texas speed and performance they have good prices and weve got alot from them...
Old Jul 24, 2009 | 07:51 PM
89lt1's Avatar
Re: lq4 bottom end
i want to do a carb'd 6.0 with l92 heads and a comp xer287hr cam 11-1 cr and some 4.10's or 4.56's out back
and thanks for all the good info
Old Jul 24, 2009 | 08:04 PM
BlueZee28's Avatar
Re: lq4 bottom end
Actually that's exactly what I did with mine, except mine has a small bore/hone job......has forged pistons and rods, and Texas Speed's MS4 cam. It should be close to 500hp when I get it in the car and running.
Old Jul 24, 2009 | 10:06 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: lq4 bottom end
I searched on LS1 tech and i can't find a single post about a guy busting his stock lq4 crank. Best to put katech or arp rod bolts in though. go all out and get tsp's 408 stroker kit
Old Jul 24, 2009 | 11:12 PM
89lt1's Avatar
Re: lq4 bottom end
if only i had the money... its somewhat of a budget build.... budgetish lol ls swaps arent cheap
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Stryker412
Sep 7, 2015 09:11 AM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
