Do I have the right fuel pump for my LS1?
Old Jul 26, 2009 | 06:47 PM
25thAnn_RS's Avatar
Car: 92 Camaro RS
Axle/Gears: 4.10
I have a Walbro gss340m fuel pump. On the box it says it puts out 43.5psi. The LS1 requires 58psi. I bought the pump from Hawks, ment for an LSx swap. Did I get the wrong part, or do I not understand how fuel systems work? I understand how the fuel pressure regulator works, but I thought the fuel pump would have to put out enough pressure also.
I start my swap in a few days. I want to have the right parts when I start. Any help is appreciated. Thanks.
Old Jul 28, 2009 | 09:30 AM
kubus_stroinski's Avatar
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
Re: Do I have the right fuel pump for my LS1?
That pump is fine. You shouldnt have an issue.
Upgrade your wiring to it though. I've killed 3 pumps because I didnt bother to upgrade the wiring. Ive since moved to an inline pump.
Old Jul 28, 2009 | 10:13 AM
25thAnn_RS's Avatar
Car: 92 Camaro RS
Axle/Gears: 4.10
Thanks for the help kubus. I got the kit that comes with the wiring upgrade. Should be starting in a couple of days. I'll post the swap if anyone is intrested.
Old Jul 28, 2009 | 10:50 AM
screeminchicken's Avatar
Post up with a lot of pictures and discription. We are all intrested.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
92camaroJoe
Aug 13, 2015 06:07 AM
