LS1 alternator on a 5.3
Old Jul 29, 2009 | 11:33 AM
bad67ss's Avatar
Car: 92 Z28 LS1 4L60E swap
Does anyone have any pics so i can see how this dang camaro bracket fits on a 5.3? I am almost ready to start the swap i am just finishing up changing everything from my 5.3 to LS1. Thanks for everyones help so far
Old Jul 29, 2009 | 03:27 PM
phillip_helmet's Avatar
Car: '84 Camaro
Engine: 5.3l TSP 224r
Transmission: TH350 3600 stall
Axle/Gears: LS1 3.23
Re: LS1 alternator on a 5.3
You'll have to drill and tap a hole on the block for it to work. There's a mounting boss there, but it's not drilled/tapped. You'll need an m10x1.5 tap. You only use the outer two holes on the bracket, the center hole isn't used. Hope that helps.
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
