which LSX PCM?
Old Jul 30, 2009 | 12:24 PM
Firebat's Avatar
which LSX PCM?
What would be the best PCM to go with for a LS2-based swap/build? I'm thinking GENIII(LS1) because of tuning. Doesn't the 1998 PCM allow the temp gauge to read the actual engine temp?
Old Jul 30, 2009 | 01:44 PM
andrew69_04's Avatar
Car: 92 Camaro RS
Re: which LSX PCM?
if you can, i would run 99-02 LSx pcm. the 98s show actual temp but thats not computer related. The 98's ran a diff temp sensor in the driver side head that has 3 prongs instead of 2. the 3rd pin ran to the gauge cluster reading ACTUAL temp. 98;s are harder to tune also, or so i've been told. if your ls2 is DBW, you will need a pcm that supports it.
Old Jul 30, 2009 | 10:03 PM
kevinc's Avatar
Car: 1982 Z28
Re: which LSX PCM?
I'm running an '01 PCM, with a '98 coolant temp sensor...best of both worlds.
The '98 sensor has a 3rd pin on it which feeds a conventional temp gauge. It's not completely accurate with the 3rd gen dash gauge, but it has good precision.
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Buggy Disaster
Sep 22, 2015 01:15 PM
