4l80e harness ???
Old Jul 31, 2009 | 11:33 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
4l80e harness ???
I'm selling the trans i got with my 6.0L. Can i just cut the harness about where the converter is is send it with the buyer? I'd obviously cut it after the oil pressure sender ( at least i think it is, top rear sesnor on block)
Old Aug 1, 2009 | 10:14 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Re: 4l80e harness ???
it would help them the most if they had all the wires to the pcm (including the little pin connectors that plug into the pcm)
Old Aug 1, 2009 | 06:32 PM
Pocket's Avatar
Car: 91 Trans Am
De-pinning a LT1 or LSx PCm is simple and requires no tools what-so-ever
Dont just snip it
Old Aug 2, 2009 | 12:40 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Is one of the sensors on the trans the reverse light though? Or can i de-pin all the wires on it since i'm using a manual? also, i take it i'd just follow the wire all the way to the pcm plug ins, but then how do i get them outa the plug in?
Thanks guys i couldn't be doing half of this without you lol
Old Aug 2, 2009 | 06:50 AM
Pocket's Avatar
Car: 91 Trans Am
You need to remove the colored pieces using something small, a screwdriver or thin piece of metal
Next pull the trim covers covering the wires by pinching them
Use your fingernail to pull the white tab back and the pin should push out
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
efiguy
Sep 27, 2015 01:30 PM
