Custom made LT1 Swap Power Steering Lines
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Is anyone interested in power steering lines?
I will be making myself a set in the next couple of days for my own swap and will make a few sets if anyone is interested.
They will be made of 5000 PSI Hydaulic Hose with a 90 end on the power steering box side and a straight end on the pump side. Will be made with 3/8 hose which is the same size as 6an. You will need the two adapters that thread into the power steering box and pump to connect these lines. I can make likned with the proper o-ring fitting on the ends but would cost more.
Will do them for 40 buks a hose that is for a 5 foot long or 45 for a 6 foot.
I will post some pics up later. If there is anyinterest Lmk because I will not do this again just thought I would help out fellow third gen members.
Thanks, Josh
Thanks, Josh
colton_carlson
Mar 8, 2019 12:21 PM
