LS1 into 88 Camaro wiring help
Old Apr 2, 2010 | 09:50 AM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Hi guys, I've gotten most of my swap finished, but need a little wiring info. When I was disecting my harness from the C100 connector, I found that there's a brown wire that is connected to the alternator, pin L that goes to the volt meter. I know the LS1 alternator does not use anything like this. My question is , if this wire is deleted will my volt meter work ? If not how do I get it to work with the LS1 type alternator ? Thanks in advance, Dean
Old Apr 2, 2010 | 10:27 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Re: LS1 into 88 Camaro wiring help
My 87 GTA had the same wire and I was told to leave it off. I did and my voltmeter works fine.
Old Apr 2, 2010 | 10:47 PM
Pocket's Avatar
Car: 91 Trans Am
3rd gen charge gauges are hooked directly into the main electrical system so they monitor the whole system rather than just the alt output. The wire is not reused for a LSx swap. LT1's do use it though
Old Apr 2, 2010 | 11:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The gauge in a factory 3rd gen instrument panel is a volt meter, so it just goes between the switched power and ground. Doesn't get anything directly from the engine compartment.
Old Apr 3, 2010 | 04:02 AM
DeanJ's Avatar
Engine: LS6
Thanks guys, maybe I can wrap this wiring up today. You guys on thirdgen have been so much help. Even though this is the only question I've asked about the swap directly, so many have been answered. Thanks again, Dean
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
1984HO
Mar 19, 2021 11:59 AM
Caspar
Jun 19, 2016 11:19 PM
reiderz iroc
Aug 13, 2015 04:57 PM
