Lt1 radiator heater core hoses
Old Aug 12, 2009 | 03:28 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Doin the lt1 swap here is the drawing i stole off of shbox sorry shoebox
Do i route my lines like this?
Wont there be constant heat running through?
Can i put my heater valve in there somehow?
Old Aug 14, 2009 | 06:50 AM
Firebat's Avatar
Re: Lt1 radiator heater core hoses
I had the auto store cut me like 6 ft of 5/8" and 3/4" hose. Ran them directly from the water pump to the heater core, having the hoses run on top of the engine.
If I stay LTx-based, I'm going to run thirdgen metal heater lines somehow.
If you want to have a heater valve, I would recommend one with only 2 connections, not 3, the 2 style one is easier to put in. Then just run the vacuum line to it that was connected to your old heater valve.
Bubbajones_ya
Jul 6, 2024 08:32 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
codeysabatini
Nov 10, 2015 04:07 PM
Formula8r89
Sep 22, 2015 04:24 PM
Stryker412
Sep 20, 2015 06:59 PM
