lt1/ls1 cylander and fire order
Old Aug 16, 2009 | 06:45 PM
timeflyere6's Avatar
Car: 1992 camaro rs 25th aniversery
Engine: crapy 305 tbi
Transmission: blown 700r4
Axle/Gears: stock
ok got this crazy idea might work i want to mod my lt1. I Am planning to change my ignition set up by moving the location of the opti spark. My idea will be changing the cam dowel so I can use an Ignition control modual with caps from possibly an Ls1 or another engine that uses I control modual for the ignition set up so that I can increase spark power and make tune up easier. what I need though is the firring order for both engines and cylinder locations as well as travel hight for pistons in both engines If my theory works which it should I'll post what i did and how Im pretty sure that the ls1 will be closest
Old Aug 16, 2009 | 06:52 PM
Axle/Gears: stock
Re: lt1/ls1 cylander and fire order
also I need to know when and what cylinders are at detonation together at what time on both engines
Old Aug 20, 2009 | 09:11 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
LT1 firing order: 1-8-4-3-6-5-7-2
LS1 firing order: 1-8-7-2-6-5-4-3
I know its not everything you need, but its a start
Old Aug 20, 2009 | 03:09 PM
Axle/Gears: stock
thanks that it is i know my idea sounds crazy but if this works i mean were looking at a whole new area of preformance
Old Aug 20, 2009 | 06:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The LS1 doesn't have a control module or cap. It has one coil per cylinder.
Old Aug 20, 2009 | 08:04 PM
Axle/Gears: stock
interesting even better so the pcm controls it completely i didnt know that well i can work with that
Old Aug 20, 2009 | 08:40 PM
kevinc's Avatar
Car: 1982 Z28
Quite a bit has been done along the lines of what you're proposing, as far back as 2002 people were running LS1 coil packs, etc.
You might check a board more focused on the LT1, like camaroz28.com and search for "Electromotive" for example.
Old Aug 20, 2009 | 08:44 PM
Axle/Gears: stock
thanks man
Old Aug 22, 2009 | 09:49 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Why not pull the intake and have it machined for a regular distributor and then run a megasquirt setup? Would be pretty simple, wiring would be easy and it would basically run like a regular SBC at that point.
Old Aug 22, 2009 | 10:39 PM
Pocket's Avatar
Car: 91 Trans Am
If he mods it for a distributor then he can run a 730 ECM on it
KCG
Jun 24, 2020 04:33 AM
djmarch
May 8, 2016 11:32 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
camarohelp
Sep 22, 2015 03:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
