installing ls1 and trans from top
Old Aug 23, 2009 | 09:44 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
i am finally ready to bolt my ls6/4l60e in. i would like to install it from above and not from the bottom with k member. my heater box and windshied motor is removed. is there anything else i should watch out for or is it that much easier from the bottom? thanks for any help.
Old Aug 23, 2009 | 10:26 AM
Pocket's Avatar
Car: 91 Trans Am
Re: installing ls1 and trans from top
Its almost always easier from the bottom even with the original engine
Pull your coils and keep a sharp eye on your tailshaft as you drop it in. The oilpan is very tight to the K member so get the engine as far back to the firewall before you do the final set-down
Pull the exhaust manifolds/headers too. They will snag on anything and everything
Old Aug 23, 2009 | 10:45 AM
macdadyZ28's Avatar
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Axle/Gears: 3.23 posi
I pull the intake and coils off because I dont trust the chain around either. tape off your intake ports. Get the nose of the car high in the air so you dont have to worry much about the tail. Just have to lower it in real slow, keep moving back closer and closer to the firewall as the oil pan clears and then lower some more, eventually the pan will clear the pan and it should sink right in onto the mount brackets.
Old Aug 23, 2009 | 10:57 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I didn't pull a thing and dropped it in from the top.
Next time I would probably pull the starter and oil filter as they bit on the motor mounts.
Old Aug 29, 2009 | 03:37 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
I am using a 4l80e and combined from the top and with the stock k-member was not happening, without firewall mods. I have a lift so I seperated, engine first. Very fast that way... like stock. Spent more time finding out it wouldn't go, then puting it in seperate and bolting it all up. lol
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
dhonda200
Aug 11, 2015 11:50 PM
