LT1 Swap for my 305 Carb
Old Aug 29, 2009 | 01:47 PM
poho's Avatar
Car: 1987 Firebird Formula
Engine: 305 w/Edelbrock carb
Transmission: 5 speed manual
I saw a recent craigslist posting where I could get most of the core parts for an LT1 for fairly cheap, but I'm wondering what will I need to do in all to make this work. Just some things here...
How much would a descent aggresive cam cost?
How about an aluminum driveshaft?
Will I need to upgrade my basic 5 speed manual w/ hurst short throw on it? and how much will that be.
I'm still looking around for a posi rear end. Figure those are around 200-400?
Anyways just an overall list of all the little things I'll need to swap, like ECU or whatever that most people don't think of when they decide to swap. Thanks for the help.
Old Aug 29, 2009 | 11:28 PM
88 Iroc Project's Avatar
Car: 88 Iroc TT
Engine: Gen 2 LT1 Carbed
Transmission: WC T5
Axle/Gears: 10 Bolt
Re: LT1 Swap for my 305 Carb
You've left this pretty wide open. What is your goal with the project? You will do better reading some of the threads already posted.There are alot of threads on this swap under the https://www.thirdgen.org/forums/engi...questions.html
and
https://www.thirdgen.org/forums/engi...1-lt1-tpi.html
I cant offer alot of technical advice yet as I'm in the middle of a 305tpi to 350 LT1 (carbed) swap myself. I would suggest doing a ton of reading as i have then ask more specific questions as you go.
Summit has great prices on new items and you can also find some good deals right here in the classifieds
good luck!
Old Aug 30, 2009 | 03:45 AM
poho's Avatar
one of my goals was to leave it more open ended so anyone can just chip in advice. Just little tid bits about "hey watch out for this" or "If you do this like this it'll be a lot easier"
Also I'm trying to avoid ordering online, seeing as how I don't have a credit card and I don't want to have to borrow one. Thanks though, it'll give me a good idea on pricing.
Since it is a core block with some accesories my goal would be to finish it off, and along the way for the stuff I need put in a few performance pieces here and there. Maybe finish it off at 325hp+? I prefer torque to horsepower though.
Hey I read through some of those other ones, and looked it up a bit on wikipedia. Basically an LT4 is what I think I'd be looking at. Or close to it, an LT1 operating like an LT4 because of the cam and whatever. (My budget would be under 600$ so I don't think this'll work out, but it'll be good future reference.
Old Aug 30, 2009 | 06:24 AM
third_genbowtie's Avatar
Car: 1991 camaro RS
Engine: 305-LT1 swap
Transmission: 700
this helped me out alot because i'm doing the same to my 91 305. swap to 96 vette LT... some things i also got...
Comp Cams "CC503" Grind# 276HR-12 part# 07-503-8 $250
Comp Cams beehive springs part# 26918-16 $174
Comp Cams spring locators pat# 4705-16 $34
Comp Cams retainters part# 787-16 $50
Comp Cams valve locks part# 648-16 $23
Comp Cams Pro Mag 7/16" 1.6 rr's part# 1305-16 $290
ARP 7/16" rocker arm studs part# 134-7103 $38
TrickFlow guideplates part# 30400623-8 $16
TrickFlow 7.2" chromemoly pushrods part# 21407200 $87
Felpro replacement valve seals part# SS72861 $19
http://www.geocities.com/texaslt1/lt1swap/swap.html
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
