lt1,th350 into 90 rs
Old Aug 31, 2009 | 08:43 PM
johnmartinez509's Avatar
i got a 1990 camaro rs, i just bought a lt1 out of 96 impala ss with 70,xxx
and a th350,what will i need for the full swap?
Old Sep 4, 2009 | 11:59 AM
Firebat's Avatar
Re: lt1,th350 into 90 rs
To get the th350 to work with the LTx, you need: dipstick, lt1 computer programmed right, correct speedometer output
1. A flexible or aftermarket dipstick like Lokar brand
2. LT1 programmed so automatic transmission trouble codes won't appear
3. A way to get the speedo to work. On a 700r4, you get a '95 camaro 4l60e reluctor, 4l60e vss, and 4l60e rear housing. You would pound on the 4l60e reluctor, bolt on the 4l60e rear housing, then bolt in the 95 vss. On a th350 you may be able to do the same thing but i don't know.
Old Sep 5, 2009 | 12:46 AM
Pocket's Avatar
Car: 91 Trans Am
You need a 9" tailhousing TH350 to do the above and when you do even the old driveshaft will fit without issue
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
89newfun
Sep 16, 2015 09:28 AM
L0tuS
Sep 4, 2015 11:16 PM
