need a part number - cyl. head plug for coolant temp sensor holes
Old Oct 9, 2009 | 07:36 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
When I bought my heads they were bare, so I didn't realize I was missing a plug until just now. Both heads have a threaded hole for the coolant temp sensor, I bought a sensor and stuck it in the driver side head because I won't have room for it on the passenger side with the HVAC equipment over there. So now I'm trying to track down a plug for the other hole on the passenger side head. I know it's a metric thread, but not sure what size. If anyone has a part number that would be awesome.
Also, I had another question relating to the heads. If you look at this picture (passenger side head), you'll see the hole I was referring to directly to the left of the header flange. Then there is another small to the left of THAT. What is this other hole? Does that need to be plugged to? If so, part number for that as well please.
Old Oct 9, 2009 | 09:09 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Re: need a part number - cyl. head plug for coolant temp sensor holes
I'm going to go out on a limb and say if
A solution is to take a factory sensor for your car, grind it down and run a 12mm x 1.5 die down it to thread it
That the hole is 12mm x1.5
You can also see in the pic i have nothing the other hole.
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
fonzie85
Aug 13, 2015 11:50 AM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
