HELP-- trying to put lt1 into a camaro rs
Old Oct 18, 2009 | 04:09 PM
camarodude05's Avatar
I have a 92 rs that is tbi and im trying to put a 95 lt1. It came with a ecu for a 95, a new wiring harness, i think its a stand alone harness. Its alot different than the one that i took out of the rs. my ? is what do i have to do to connect everything right. the new harness doesnt have the the connectors for the rs body. should i try to find a harness and ecu for a 92 tpi, or will anything else work?
Old Oct 19, 2009 | 10:25 AM
Cg-OneSic89's Avatar
Car: 1984 Z28 L69
Engine: Cammed 350
Transmission: Tremec Tr-3550
Re: HELP-- trying to put lt1 into a camaro rs
that new harness is probably a stand alone unit meaning all it needs is a power and a ground to run. Tpi electronics will not run an Lt1 to my knowledge, nor will it be worth the swap.
Old Oct 19, 2009 | 04:32 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Any way to post a pic of what you got?? Here is a link that will get you started on the wiring.
http://www.cz28.com/forums/showthread.php?t=474185
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Thirim
Aug 9, 2015 06:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
