still having idle problems
Old Oct 24, 2009 | 10:36 PM
ScorchedPaint's Avatar
Car: 1992 Camaro RS
Engine: Ls1
Axle/Gears: 4th gen 3:43
I have tried to wire in a HPTuners computer and the laptop wont recognize that the car is on. I have full contact and proper grounding and have tested all wires and still the tuner wont read the power coming from the car!?? I checked continuity from the pcm to the connector, checked voltage and everything! why wont hptuners recognize that the connector is hooked up?
I tested the wiring on the car and everything is getting power because the engine runs fine when i have just a little gas applied but as soon as i let go the engine dies....
I have checked to see if there is a vacuum leak and cant find any....
LOST!!!! Any suggestions??
Old Oct 26, 2009 | 03:19 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: still having idle problems
I dont think anyone will object to this link here....
http://www.hptuners.com/forum/
Thats where you want to post
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
