lt1 schrader valve problem please help!
Old Oct 27, 2009 | 01:16 AM
bmfIROC-Z's Avatar
well i was installing my nitrous kit and when i connected the the fuel line to the schrader valve i must have tightened it a little to much cause now there is a hair line crack where the schrader valve connects to the fuel line and its leakin pretty good,anybody ever have this problem?what should i do to fix it?would jb weld or quick steel do the job?any suggestions would be appreciated.
Old Oct 27, 2009 | 02:20 AM
wickedowesix's Avatar
Re: lt1 schrader valve problem please help!
IMO you should just buy some new or used rails and not risk the leak
Old Oct 27, 2009 | 06:41 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Either pull the rails, and take them to a GOOD tig welder, and have them weld on a new -an fitting...or get new rails. Dont mess around with fuel connections like that. JB Weld might work...until it doesnt work. Then you've got a fire.
J.
Old Oct 27, 2009 | 09:01 AM
bmfIROC-Z's Avatar
J.
lol,yeah thats what i figured,im either gonna get it welded or get a new.
Old Nov 2, 2009 | 01:21 AM
cusz28's Avatar
Car: 1983 Z28
Transmission: 700r4, 2500 stall, shift kit.
Axle/Gears: 85' iroc open diff w/3.08 gears
you can try brazing the crack shut. just pull the rail and line out, completely dry it out, clean the metal, and braze it back on with a propane torch. just take the schraeder core out when you do it so you don;t melt the seal, then put a new one in it. I work on refer trailers and thats all i do to fix refrigerant leaks and its good for some outrageous 500 psi as long as the metal is clean when you start.
Old Nov 2, 2009 | 08:30 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
gas leaks are not one of those areas you want to play around with. nothing puts a damper in your day like a nice engine fire.
i'd search around the 4th gen sites to see if you can find a used set. shouldn't be too bad in price.
Old Nov 2, 2009 | 08:43 AM
cusz28's Avatar
Car: 1983 Z28
as would i. but the whole point of the forum is to give the original poster options and opinions. of course getting a new one is the best way to go, safe and trouble free, but it's not his only option, thats the whole reason why he asked. they're easy to find too. get one from a b body with either a l99 4.3 v8 or lt1 if you can't find an f body
midge54
Dec 27, 2019 04:14 PM
db057
Aug 22, 2015 08:17 PM
R3500
Aug 17, 2015 12:16 PM
sreZ28
Aug 14, 2015 07:48 PM
