Is a lower shift boot really necessary?
Old Oct 28, 2009 | 08:33 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I kind of forgot to order one, was going to buy one from an LT1 or LS1 car and hopefully it would fit right, but alas I forgot to get it. So now here I am, getting ready to drop the motor and trans in on Saturday and even if I buy one online it probably won't be here by Saturday.
So is it absolutely necessary to have a stock-ish looking rubber boot? Or can you make something that will do the job just as well? What have some of you guys made to use as a lower boot? I'm thinking the hole that I cut wouldn't fit well with a stock GM boot anyways, it's not a perfect looking hole. Has anyone tried to rig up something that worked well for them?
Old Oct 28, 2009 | 09:27 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: Is a lower shift boot really necessary?
the T56 puts out a lot of heat, and not having that rubber boot makes the shifter really toasty... and the car drafty and noisey
I have one from a 4th gen car.... $10 plus shipping if you want it
-jason
Old Oct 28, 2009 | 09:38 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
From what I've read, it does a fair bit to block noise & fumes from entering the car, so you'll probably want something there. Is there any way to work around it for a few days?? Maybe concentrate on other areas of the swap?
Old Oct 28, 2009 | 09:40 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I didn't have one. I plan on getting one.
I've been riding without it for several months now... but it's definitely something you'll want to have in there. The amount of heat that comes through there is insane.
Old Oct 28, 2009 | 09:48 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
What he said. I'm probably going to taking care of this over the winter. one of many finishing touches
Old Oct 29, 2009 | 10:43 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
"Need" is a relative term. You dont need it but you probably really REALY want it. I just put mine on from the bottom side up and sealed it in with seam sealer. Fast, clean, best of all really easy install.
Old Oct 29, 2009 | 11:07 AM
BlueZee28's Avatar
I am getting one from JayZ28 and going to install it from inside the car like on the 4th gens, I'll probably have to rig up another piece of rubber to completely seal the hole because I think I cut the hole too big, but I'll figure something out.
Old Oct 30, 2009 | 09:19 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
just for future reference, here is an exploded view of the part (number 4) and here is the part number: 10267518
Old Oct 31, 2009 | 01:15 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Unless you cut the hole HUGE, the GM one should work fine. I actually just went to Schucks and grabbed one of those universal spectre rubber puts with a metal retainer ring and bend each side to fit. It was supposed to be a temp fix but ran like that for a good 3 years before I finally ordered up a GM one. Which still didn't fit the floorpan perfectly...
Old Dec 19, 2009 | 03:46 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Sorry to hijack the thread, but with a stock third-gen T5 lower boot work with a T56?
Old Dec 20, 2009 | 05:21 AM
TexasLT1's Avatar
Car: '92 RS
It does but just barely. You end up stretching it pretty close to the limit but it fits. I'd like to replace mine with the T-56 piece one of these days.
Old Dec 20, 2009 | 06:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not finding that part or part number.
Old Dec 20, 2009 | 06:09 PM
Car: '91 LS6/T56/9"
Engine: LS6
It's the right number
http://www.byunspeed.com/product_inf...d738cbd5ed0493
Old Dec 20, 2009 | 06:36 PM
five7kid's Avatar
Hey, right in my back yard as well!
Thanks, I did a search, tried gmpartsdirect, came up blank.
Old Dec 20, 2009 | 09:35 PM
five7kid's Avatar
Originally Posted by robguitargod1
Well, I ordered it through them, got an order confirmation, then an order cancellation saying the item is no longer available.
I'm thinking the lower boot is no longer available.
Old Dec 23, 2009 | 04:03 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Think this one would be fairly close? Its from the c3 corvette, there's a whole bunch of them for sale on ebay.. I was looking for a t56 shift boot too and can't find one anywhere.
Old Dec 23, 2009 | 04:13 PM
Car: '91 LS6/T56/9"
Engine: LS6
Good call since it's not an overly critical part that must come from a camaro. I'm sure the vette one will work great.
F-body driver
Mar 6, 2023 11:44 AM
J-money
Jan 4, 2019 09:45 AM
BOOT77
Sep 5, 2015 03:55 PM
tonys91rs
Sep 2, 2015 07:07 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
