wiring help needed
Old Nov 1, 2009 | 05:16 PM
bad67ss's Avatar
Car: 92 Z28 LS1 4L60E swap
wiring help needed
Ok so the harness is almost completed but a couple questions, on the stickie about modding the original harness for the LS1 swap it says to connect the TCC to R2, now which TCC? on the C100 pin E7 is a TCC and also on the C207 pin H is also TCC. Also R2 is the TCC solenoid so shouldnt you connect the TCC to pin B33 TCC brake switch instead?
Old Nov 5, 2009 | 06:28 PM
Pocket's Avatar
Car: 91 Trans Am
Re: wiring help needed
I had to think about your question for a while. I think you pointed out an error in the write up
Here is the 3rd gen TCC circuit
http://www.austinthirdgen.org/mkport...8_vinE_TCC.jpg
Here is the same for a 4th gen
http://www.lt1swap.com/pictures/16_a...amp_switch.gif
R2 goes to the trans connector and B33 to E7 on the C100
Pin H on the C207 is not used
Guide has been updated
IROCZ1989
Jan 24, 2016 03:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
apie2546
Aug 8, 2015 07:12 AM
