Boost possible with LS1 w/ trick flow kit?
Old Nov 3, 2009 | 08:56 AM
mtflyboy's Avatar
Car: 1991 Z28
So I am still saving up for my LS1 swap, but since i'm going to taking the engine apart to make sure it doesnt have any problems (you can never really trust a wrecked pull out) i figure i should put some power in it while i have it apart. i was looking at the trickflow 515 hp kit.
http://www.summitracing.com/parts/TFS-K306-515-460/
i am sure the guy i have helping me build it can help me find a cheaper way to get the engine over 500 horses, but i was wondering if with a top end built engine it is still possible to go turbo.
or would a supercharger work better. i am not very knowledgeable about turbos and superchargers never having worked with them so any help would be much appreciated.
-wes
Old Nov 3, 2009 | 09:07 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: Boost possible with LS1 w/ trick flow kit?
Theres loads of pump gas street friendly boosted LS1's ( turbo or SC ) running safely in the 500-550 rwhp range. Theres braver ones who have taken a stock bottom end car to over 750 rwhp but dont expect it to last very long if you get crazy.
Old Nov 3, 2009 | 10:22 AM
mtflyboy's Avatar
Car: 1991 Z28
alright thanks... i will be starting my build post soon haha... is there are board for just full builds for an entire car not just engine?
Old Nov 4, 2009 | 11:33 AM
82z28man's Avatar
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
If your planing to go with forced induction I wouldnt waste your money on any of the trick flow kits. I would rather build a good forged bottom end with low compression. Then maybe do a turbo cam or an ls6 cam also works good for boost with a wide LSA. Then while you have th heads off maybe do a quick port and polish. The heads arent going to be quite as critical on an F/I apllication as it would be on a N/A motor, the air is going to be forced in anyways. Just my opinion, good luck with it.
customblackbird
Oct 1, 2015 04:30 PM
sleprock
Oct 1, 2015 09:39 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
Dragonsys
Sep 25, 2015 03:51 PM
