LSx w/ thirdgen cruise?
Old Nov 4, 2009 | 02:10 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Maybe I'm missing something here because it's been a couple months since I went over the wiring but as long as a vss signal is given to the thirdgen cruise control module; Can't I just hook a cable to the TB and it'll work like factory? If so, what cable? A thirdgens end is too long with respect to the mounting clip. Maybe I have to make another bracket?
Old Nov 4, 2009 | 05:04 PM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
Re: LSx w/ thirdgen cruise?
not sure how you'd get the thirdgen one to work, but i have the cruise module with the throttle cables and everything off a fourth gen sitting in the garage if you need it. pm me if you're interested. i just got it before i knew i would end up going dbw and i cant use it now.
Old Nov 5, 2009 | 11:01 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Thank you. However, I never get rid of the thirdgen cruise and actually hooked the spare vss signal wire up to the stock harness and get activation while in motion. Hoping I can just hook a cable to the TB and rocknroll...
Old Nov 5, 2009 | 12:38 PM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
have you checked to see if a non-tc 4th gen cruise cable will work? i would think it would work if you could get the cruise module end of it to mate to the 3rd gen module. hmm, i have both in the garage, i might have to go take a look at them and see if you could just get the 4th gen cruise throttle cable to go with the third gen cruise module.
Old Nov 7, 2009 | 02:26 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I started on that a while back. I enlarged the slot on the bracket that goldsthe throttle cable and cruise cable. Fit great. I gave up on it and will have to get an original bracket to hook up the typical 4th gen cruise cable. I'll swap you brackets if you want - will work with the 3rd gen cruise and a 4th gen throttle. Just Pm me.
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
Buggy Disaster
Sep 22, 2015 01:15 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
Kurt88IROC
Oct 26, 2009 05:59 PM
chaoz28
Nov 25, 2008 02:29 PM
