LSX IROC on hold
Old Nov 7, 2009 | 06:17 AM
TecHunter's Avatar
LSX IROC on hold
So far all I have is the car whom i have had since 1991, compstar rods, LSX block, wire harness, ecm, vortech super charger s-trim too small. I hope to be updating this thread soon. For now i had too install a voodoo 60103 and start slapping my 355 back together. Boy oh boy, such bad times i tell ya bad times
Attached Thumbnails LSX IROC on hold-pic2-20copy.jpg   LSX IROC on hold-dscf0793-20copy.jpg   LSX IROC on hold-dscf0791.jpg
Old Nov 7, 2009 | 06:22 AM
TecHunter's Avatar
Re: LSX IROC on hold
Couple more pics!
Attached Thumbnails LSX IROC on hold-dscf0794-copy.jpg   LSX IROC on hold-pic1.jpg
Old Nov 7, 2009 | 10:53 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Yea, to gte my big block together faster, due to lack of funds, iam going to have to use oval port heads and a damn flat tappet cam shaft, sucks so badly since i am going ot be stepping back from 600+ HP down to 550 or so. SUCKS.
I would do a cheap *** 5.3 or 6.0 for sure if i had a damn T56 for a LS1, but i have a LT1 T56, so it is not going to happen. THose things are just so cheap now.
Old Nov 8, 2009 | 05:22 AM
TecHunter's Avatar
So is there not a T56 adapter for the LS? If not could you get someone too fab one?
Old Nov 8, 2009 | 07:24 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
You can interchange the bellhousing (i think) but the input shaft would need to be swapped.
Old Nov 8, 2009 | 11:19 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i understand...my 6.0L build is getting cut back a bit because of financial situations...i was originally going to go with a set of trickflow 220's...now i'm back to using STOCK 317's...
Old Nov 9, 2009 | 12:26 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
one of my stock 317's were cracked because the yard i got the pullout engine from dropped it off the fork lift when loading it... landed on the manifold and cracked all the way down the head. so i had to buy a set of 317's just to get the engine together and possibly runable
Old Nov 9, 2009 | 08:42 PM
poofy95's Avatar
Car: '86 Z28
Engine: LSX swap in progress...
Axle/Gears: 3.48
Is that one of the new GMPP LSX blocks!?!? It's even more beautiful than I imagined...
EDIT: It's a 376, right?
Old Nov 9, 2009 | 09:00 PM
mw66nova's Avatar
Engine: 7.0L
i hope you were able to get it at a discounted rate...i'd have pitched a fit...
Old Nov 11, 2009 | 04:48 AM
TecHunter's Avatar
Yes it is, that's the same thing I said when it arrived! I still can't decide whether to go 440cid or 454cid. But I think I'm leaning more toward 440, that way I don't have to go over a 4 inch stroke. They say for street use its not good to go over 4inches of stroke.
Old Nov 14, 2009 | 04:29 PM
poofy95's Avatar
Car: '86 Z28
Axle/Gears: 3.48
Oh. That makes sense. I'm going to do an LS1 swap once I have enough money to do anything at all. Lol.
Old Nov 14, 2009 | 07:06 PM
Omega's Avatar
Engine: LS1 / LS3
Personally a 427 has a nice ring to it. Nothing like spinning a big block to 7K
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Wade787b
Sep 29, 2015 01:15 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
mustangman65_79
Aug 11, 2015 03:17 PM
