ls1 fuel pump?
Old Dec 3, 2009 | 07:56 AM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
ls1 fuel pump?
can i use the hawks fuel pump and wiring kit(link below) for a third gen. with ls1 installed. does the fuel pump wiring have to go thru the pcm? i am currently running a ls1 with the stock third gen fuel tank and pump with a after market wiring harness that has it's own fuel pump wirng and relay.
i would like to upgrade the wiring going back to the tank.
http://www.hawksthirdgenparts.com/85...pumpkit-1.aspx
Old Dec 3, 2009 | 09:19 AM
Pocket's Avatar
Car: 91 Trans Am
Re: ls1 fuel pump?
Forget the kit, just get a pump
This is how 3rd gens do the relay and pump
Since you've already got a relay in place, simply find its output wire. For 3rd gens it is gray. Make sure it it atleast 16ga wire
In the wiring to your tank there should be 3 wires. Splice the relay output to the gray wire going to your tank. It should operate like stock now
The kit complains factory wiring is too small, yet plugs into an inline connector near the tank. The tank wiring is not changed so the 'terrible' wiring is still in place
Old Dec 3, 2009 | 12:10 PM
ls6iroc's Avatar
Car: 89 iroc
Engine: ls6
Transmission: 4l60e
Re: ls1 fuel pump?
pretty simple. thanks for the help pocket!
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
92camaroJoe
Aug 13, 2015 06:07 AM
