what hints to look for in a LSX tree W/out the obvious
Old Dec 11, 2009 | 03:09 PM
morbital's Avatar
Car: '89 Camaro RS
Engine: 5.7 LS1
Transmission: 6 SPD.
Axle/Gears: 3.25
hello all!
well here's the deal, we all know what a LS engine looks like, let's face it, its pretty simple. but there's a person claiming on selling me a LS3 engine that he replaced his ls1 engine on his 01 bird. The deal is sweet, so im planning on meeting the guy and claims it is a ls3 with all the wiring, ecm, 6SPD, and everything i need for a swap. he adds that it does not have the V-serpentine stuff, oil pan, coil covers, INTAKE and the engine has been sitting in a shell for a while due to "change of plans". like i said i know what a LS engine looks like, and i can somewhat know where things are like relocated cam sensors, etc. as the years go by.. but dont know much as far as knowing the little details as what is an ls1-3 or 7 looks like . all the hints are not there.Is there a a stamp somewhere in the engine that might give out what family tree it belongs to? if you have 2 LSX engines side by side, 1 a LS1 and a LS3, can anyone know which is which besides the coil cover giveaway.. I made a search but it explains things that i allready know like power and stroke blah, blah, blah... comments would be apreciated to figure out my dilema.. thanks.
Old Dec 11, 2009 | 09:39 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: what hints to look for in a LSX tree W/out the obvious
Go onto LS1Tech.com,,, get a user name and find the right message board within LS1Tech and ask that question. Thats your best bet to get a good answer.
Old Dec 12, 2009 | 04:45 AM
one92rs's Avatar
Car: SOLD!!!!!
http://www.camarohomepage.com/ls3/
http://www.gmhightechperformance.com...ure/index.html
try those.
Old Dec 12, 2009 | 12:25 PM
morbital's Avatar
Car: '89 Camaro RS
Engine: 5.7 LS1
Axle/Gears: 3.25
one92rs: man those sites are specific! now i know more things on these engine! thanks
doc: i never thought of doing that, but since there are alot of thirdgen folks doing the swap i'd imagine someone might know this stuff. thanks!!
Old Dec 14, 2009 | 12:22 PM
Guest
Guest
Posts: n/a
the main thing is the head casting number. The last 3 digits are visible even with the valve covers still on. Just find out what it should be for LS3 heads.
Old Dec 14, 2009 | 02:30 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
What he said but try and get block casting numbers too. Heads can be swapped easily.
Old Dec 14, 2009 | 05:26 PM
one92rs's Avatar
Car: SOLD!!!!!
if my memory serves me right the ls3 heads had a different port on them.
here you go
http://www.gmperformanceparts.com/_r...ixPointTwo.pdf
Old Dec 14, 2009 | 06:19 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I'd assume that an LS3 should have a stamp on the backside that says "6.2"?
I know my LQ4 says "6.0" on the back, and LS1's say "5.7" and the LM7's say "5.3"...that might be another way of telling.
Old Dec 16, 2009 | 11:27 AM
morbital's Avatar
Car: '89 Camaro RS
Engine: 5.7 LS1
Axle/Gears: 3.25
yesterday i went to see the guy and looked at the engine.. it looked in pretty good shape, he sure wasn't lying about the missing things i mentioned before.. i got up and close on the engine to look at stamps or some sort of numbers to identify the engine, heads and other things, and the wierdest things were on the engine. for some reason there were some grinded spots and some deep ones too. the spots were at some specific areas, most were you guys metioned where a certain stamp would be.. but it was scratched off. i told the guy if it was an ls3, he swears it is. i told him where he got the engine from and said some guy in a shop had it. i thought it was fishy so i didnt get the engine. if there is some sort of removal to recognize the engine.. would there be a possibility of it being stolen or scam. LSX engines are so damn popular these days that you never see them in junk yards or some guy selling them like a used car. i mean what if it was a 5.3 and claiming it as a 6.0 or something.. i just had to share this strange thing. sucks tho, i wanted to walk away with a ls3, had the truck ready to take it home... gotta keep looking. i guess it goes to people who are looking for lsx engines, make sure you know what you are getting from someone by inspecting the engine carefully, dont wanna be suckered. thanks everyone for the guidance! i would have gotten the engine believing it could have been something else that might not be..
Old Dec 16, 2009 | 12:19 PM
Black_Knight's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305TPI
If you felt something was "off" with the deal then I'd say you made the right choice.
Old Dec 16, 2009 | 12:39 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Yea if identification numbers were ground off....I'd be walking away with my money in hand for sure. i'd say you def made the right choice, that situation reeks of a scam.
Old Dec 16, 2009 | 02:18 PM
Shift06's Avatar
Yeah he is either scamming you into thinking it's an LS3 when it's probably a 4.8 or something or else it is stolen.
Old Dec 16, 2009 | 05:26 PM
BlueZee28's Avatar
Was it aluminum or iron? LS3's are aluminum. Also the cylinder bore is different between a 4.8,5,3, and 6.0/6.2. I guess you could have measured the cyl walls but like the other guys said, if the block stamps were obviously ground off then something isn't right. My bet is it was either stolen or if it was aluminum, may have been an LS1 and he was trying to get more money for it.
Old Dec 16, 2009 | 10:50 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
sorry to hear about your luck, just keep looking!
Old Dec 22, 2009 | 01:57 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
If all identification marks were gone, run away as fast as you can. Not worth it. I know at least one person has recommended LS1Tech already; I grabbed my LS1 and 4L60E from someone local off there for $500; a set of heads for $100. There are deals out there if you can wait.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
