95 camaro lt1 into 89 caprice
Engine: 89 5.7 corvette motor
hey everyone i just got a 95 camaro with 158k miles i want to drop the motor an put it in my 89 caprice i the lt1 motor runs strong but i want to upgrade it while its out any suggestions on upgrades or the swap within a budget of 2000?
Transmission: 4L80E/4L80E
Technically this isn't a 3rd gen f-body swap, but I'll allow the topic as long as it's limited to the engine details.
Car: 1992 camaro
Axle/Gears: 3:73
Re: 95 camaro lt1 into 89 caprice
How much hp do you want to make? Do you want a cam only or do H/C?
http://www.elliottsportworks.com/lt1.html <-- A little better than most off the shelf cams.
well i just want help with the engine not so much the swap but advice is nice im going to take the engine down to the heads i want to get the most power i can out of 1500-2000 dollars
Car: 1992 camaro
Axle/Gears: 3:73
If you are going to do a cam swap you need room in your budget to do RR,new PR, gaskets, valve springs depending on the cam a stall... You can give Lloyd a call and tell him what you goals are and he can help with a cam.
Or these guys http://www.advancedinduction.com/AiProductsCK.html
Another vote for Advanced Induction. They do great work and are very easy to deal with. I've got a set of their CNC ported Trickflow heads on my car right now.
