cylinder head q
Old Dec 20, 2009 | 07:32 PM
jackaharmon's Avatar
Car: 1989 Pontic Trans Am GTA
Engine: old 350TPI/new LS1
Transmission: old 700R4/new 4L60E
Axle/Gears: 3.27 stock
cylinder head q
whats the difference between cylinder heads with the traditional valve cover bolts (on the outside), and the center bolt valve covers..also is there a difference in how the ignition coils mount??
Old Dec 20, 2009 | 08:02 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: cylinder head q
You are referring to LS engines right?
Old Dec 20, 2009 | 08:26 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: cylinder head q
if ls
the perimeter bolt covers were 97-98.
Old Dec 20, 2009 | 08:35 PM
Re: cylinder head q
yes i meant to say the LS motors...also can the ignition coils off a 98 camaro LS1 (with perimeter valve cover bolts) fit on the new style valve covers with center bolts..
Old Dec 20, 2009 | 10:26 PM
Car: 02 SS
Re: cylinder head q
need matching brackets.
Old Dec 21, 2009 | 08:24 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: cylinder head q
There are no difference in the flow numbers between the perimeter bolt and center bolt covers (according to my source that knows these motors inside and out) except the way the coils mount (bracket vs direct to the cover)
Cornholio7979
Sep 20, 2018 02:31 AM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
