optispark used with a carb?
Old Jan 8, 2010 | 08:38 PM
6lkl6l's Avatar
iv read that its possible to still use it with a carb setup but it would be limited to running a certain way.
the reason i ask is i cant seem to find the block off plate online anywhere
is there anyway to get rid of the opti any other way?
Old Jan 8, 2010 | 10:49 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: optispark used with a carb?
I have seen the block off plate, it worsd fine, but you can leave the opti on and it will be fine.
Old Jan 9, 2010 | 12:40 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
There's no benefit to keeping it. And no need. you can probably find the plug just by calling Scoggin-Dickey.
Old Mar 24, 2011 | 08:06 AM
Sinful 91's Avatar
Car: 91 RS Vert
Engine: 305 To Vette LT1
Axle/Gears: 9 Bolt BW 3.27
809-12367600 Jegs part for Opti cover plate my friend. Summit has the same for a few bucks more.
Old Mar 24, 2011 | 09:51 PM
Firebat's Avatar
A cheaper option may be to make your own plug - something like a piece of sheet metal/aluminum and rtv. However, if you do that then will need a universal timing pointer.
Also keep in mind you will need to buy an aftermarket balancer with timing marks to set the timing since stock balancer doesn't have them. For the balancer, Professional Products makes one that comes with a keyed hub that is under $100, at least on ebay. It comes with optional spacers for different years and models so it will work on any LT1 setup. ATI makes the best balancer but they are expensive and probably not really needed unless you have a lot more HP than stock or a supercharger.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
